captive-portal
bridge
Enables IP (IPv4 and IPv6) packet snooping on wired captive portals, and also configures the subnet to snoop. When enabled, IP packets received from wired captive portal clients, on the specified subnet, are snooped to learn IP to MAC mapping.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
captive-portal [ipv4-snooping|ipv6-snooping] subnet <IPv4/M|IPv6/M> {excluded-address <IPv4|IPv6>}
Parameters
captive-portal
[ipv4-snooping| ipv6-snooping] |
Enables snooping of IPv4 or IPv6 packets (based on the option selected) for wired captive portal clients |
subnet
<IPv4/M| IPv6/M> |
Enables IPv4 or IPv6 packet snooping on a specified subnet
- <IPv4/M|IPv6/M> – Specify the subnet address in the A.B.C.D/M or X:X::X:X/M format to identify an IPv4 or IPv6 subnet respectively. When specified, this is the IPv4/IPv6 subnet on which IP packets are to be snooped.
excluded-address
<IPv4|IPv6> |
Optional. Configures the IPv4 or IPv6 address excluded from snooping within the specified IPv4|IPv6 subnet.
- <IPv4|IPv6> – Specify the IPv4 or IPv6 address. Use this parameter to configure the gateway‘s address.
nx9500-6C8809(config-profile NX9500Test-bridge-vlan-4)#captive-portal ip-snooping subnet 192.168.13.0/24 excluded-address 192.168.13.7
nx9500-6C8809(config-profile NX9500Test-bridge-vlan-4)#show context
bridge vlan 4
ip igmp snooping
ip igmp snooping querier
ipv6 mld snooping
ipv6 mld snooping querier
Related Commands
no |
Disables IP packet snooping on wired captive portals |
